O que você precisa
Open the Case Shut down your Mac Pro, give it a few minutes to cool off, and unplug all the wires and cables. Locate the latch on the back of the case and pull it out. The latch lifts out very easily and stops after an inch or two — do not try to force it any farther.
Each bay has a number stamped on it, and they go in order from left to right. Bay #1 should contain the stock hard drive that was installed by Apple. Gently remove the bracket from the next empty hard drive bay — if you only purchased one hard drive with your computer, this should be bay it should easily slide out.
SOLUTION I THOUGHT OF:
I have the Mac Pro 1,1 (2006) and needed to remove HD 1 (near the fan). Instead of removing my secondary HD 2 next to it first, I used the metal cover to ease it out.
After opening the side cover, just slide the strongest corner below the lip of the hard drive and gently use it to loosen the HD if you cannot readily pull it out with your fingers. It took me 10 seconds to loosen then slide it out.
37 outras pessoas executaram este guia.
