Ir para o conteúdo principal
MSI VR601 WiFi card Replacement
O que você precisa
  1. MSI VR601 WiFi card Replacement, Open the back cover: passo 1, imagem 1 %32 MSI VR601 WiFi card Replacement, Open the back cover: passo 1, imagem 2 %32
    • Start by taking out the battery and charger. No power should be connected.
    • Unscrew the 4 Phillips #1 screws marked in the photo.
    • This screw is hidden under the Warranty void sticker!
    • All screws are the same length, so don't worry about mixing them up
    • Use a spudger or your finger to gently but firmly open the cover.
    • It's stuck in there with clips, so be a little careful. (Remember; If you feel like you're using too much force, you probably are).
  2. MSI VR601 WiFi card Replacement, Identify the WiFi card and remove: passo 2, imagem 1 %32 MSI VR601 WiFi card Replacement, Identify the WiFi card and remove: passo 2, imagem 2 %32
    • The WiFi card has two antenna cables (one white and one black).
    • Use a spudger to carefully unhook the antenna contacts.
    • Unscrew the Phillips #0 screw holding the WiFi card down. (This is not the same screw as the others).
  3. MSI VR601 WiFi card Replacement, Replace WiFi card: passo 3, imagem 1 %32
    • Take the old card out of the mini PCI Express slot, and replace with a new and compatible card.
    • In my case I only had a direct replacement, which only supports 802.11b/g standards.
Conclusão
Geir Ove Andersen
Membro desde: 06/06/22
7.740 Reputação
Autoria de 5 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 321
Autoria de 1.485 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 19
Duração total: 206
