Introdução
In order to start this process of taking the RAM out and putting it back in, you must remove turn off your laptop and then remove the battery. Follow the battery replacement prerequisite before starting this guide.
O que você precisa
Unscrew the four 10 mm Phillips head screws circled in red in the picture using the Phillips 00 screwdriver.
Quase terminado!
Conclusão
