Ir para o conteúdo principal
MSI PR600 MS-16372 Battery Replacement
  1. MSI PR600 MS-16372 Battery Replacement, Battery: passo 1, imagem 1 %32
    • First, turn off the computer and unplug the power cord.
    • If laptop is not unplugged from the power cord, you could be at risk of electric shock.
  2. MSI PR600 MS-16372 Battery Replacement: passo 2, imagem 1 %32
    • Flip laptop over so that you are looking at the bottom of the laptop.
    • Put your left pointer finger on the switch labeled "Battery lock" and your right pointer finger on the switch labeled "Release".
  3. MSI PR600 MS-16372 Battery Replacement: passo 3, imagem 1 %32
    • Switch the tab labeled "Battery lock" to the unlocked position.
    • Slide the tab labeled "Release" to the right and hold it down.
    • While holding the "Release" tab to the right, slide the battery out with your left hand.
Conclusão
Lauren Mewes
Membro desde: 10/21/18
361 Reputação
Autoria de 3 guias
Equipe
UC Davis, Team S4-G8, Lore Fall 2018 Membro de UC Davis, Team S4-G8, Lore Fall 2018
UCD-LORE-F18S4G8
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 338
