Introdução
This guide will show you how to replace the hard drive inside of the MSI PE70 6QE-035US. If your device is struggling to download new files or applications, replacing your hard drive could be the fix to your problem. Be sure to follow this guide on any hard surface or area that won't create any static electricity.
O que você precisa
Start by flipping the device over to the backside.
Using the Phillips #0 screwdriver bit, unscrew all screws on the back panel.
Uma outra pessoa concluiu este guia.
