Introdução
Using the MSI MS-1782, encountering trouble with the speakers, you will use this guide to replace the speakers. It is important to disconnect the battery before replacing the speakers.
O que você precisa
Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
Loosen the captive screw on the left side of the left fan using a JIS #2 screwdriver.
Remove the 5.1 mm screw on the right side of the left fan using a JIS #2 screwdriver.
Remove the four 5.5 mm screws holding the battery frame in place using a JIS #1 screwdriver.
Gently disconnect the cable connecting the M.2 caddy to the motherboard.
Pull the left speaker out, following the wire, unclipping it as you go to the next.
