Ir para o conteúdo principal
MSI MS-1782 Back Cover Replacement
O que você precisa
  1. MSI MS-1782 Back Cover Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Back Cover Replacement: passo 2, imagem 1 %32 MSI MS-1782 Back Cover Replacement: passo 2, imagem 2 %32 MSI MS-1782 Back Cover Replacement: passo 2, imagem 3 %32
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Duração total: 233
