Ir para o conteúdo principal
MSI GT75VR 7RF Titan Pro RAM Card Replacement
O que você precisa
  1. MSI GT75VR 7RF Titan Pro RAM Card Replacement, RAM Card: passo 1, imagem 1 %32
    • Unscrew each of the four screws using the Phillips #0 head on the back of the laptop case. The screws are 0.5 inches in length.
  2. MSI GT75VR 7RF Titan Pro RAM Card Replacement: passo 2, imagem 1 %32 MSI GT75VR 7RF Titan Pro RAM Card Replacement: passo 2, imagem 2 %32
    • Pop the back cover off of the laptop using the black nylon spudger.
  3. MSI GT75VR 7RF Titan Pro RAM Card Replacement: passo 3, imagem 1 %32
    • Disconnect the battery cable.
  4. MSI GT75VR 7RF Titan Pro RAM Card Replacement: passo 4, imagem 1 %32 MSI GT75VR 7RF Titan Pro RAM Card Replacement: passo 4, imagem 2 %32
    • Pry the battery pack up with the black nylon spudger.
  5. MSI GT75VR 7RF Titan Pro RAM Card Replacement: passo 5, imagem 1 %32
    • Pop the metal tabs on each side of the RAM using the black nylon spudger.
  6. MSI GT75VR 7RF Titan Pro RAM Card Replacement: passo 6, imagem 1 %32
    • Lift and remove RAM card by hand. Replace each RAM card and test them individually. If your computer encounters a RAM error with only one card inserted, you can confirm that card is corrupted.
Conclusão
Jack Crumpton
Membro desde: 08/31/18
241 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 666
