Ir para o conteúdo principal
MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement
O que você precisa
  1. MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement, CPU/GPU Chip: passo 1, imagem 1 %32 MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement, CPU/GPU Chip: passo 1, imagem 2 %32 MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement, CPU/GPU Chip: passo 1, imagem 3 %32
    • Remove the four screws from the rear laptop cover using the Phillips #0 screwdriver. The screws are 0.5 inches long.
    • Use the black nylon spudger to pry the cover off the laptop.
  2. MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement: passo 2, imagem 1 %32 MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement: passo 2, imagem 2 %32 MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement: passo 2, imagem 3 %32
    • Unplug the battery plug from the unit. Lift the battery out of the housing by prying it from the adhesive using the black nylon spudger.
  3. MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement: passo 3, imagem 1 %32
    • Remove the screws using the Phillips #0 screwdriver. Disconnect the left side fan from the unit as shown. The screws are 0.25 inches long.
  4. MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement: passo 4, imagem 1 %32 MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement: passo 4, imagem 2 %32
    • Unscrew the CPU cooling plate using the Phillips #0 screwdriver. Lift the cooling pipes away from the unit. Screws are 0.15625 inches long.
    • Unscrew both standoff nuts from the chip using the Phillips #0 screwdriver. Then lift and remove the unit from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 19
Duração total: 1,341
