Introdução
If you experience any issues with fans not working properly or not functioning at all, this guide will help you remove them from the computer for inspection or replacement.
O que você precisa
Remove the seven 6 mm Phillips #00 screws on the back cover of the laptop with the PH0 Bit screwdriver.
3 outras pessoas executaram este guia.
