Introdução
This guide will help you replace the screen of your MSI GT70 MS-1763 laptop. We will walk you through the steps to remove your screen in order to replace it.
O que você precisa
Remove the rubber guards covering the two 3mm screws on the bottom of the screen. Next, remove the screws with a Phillips #0 screwdriver.
Uma outra pessoa concluiu este guia.
