Ir para o conteúdo principal
MSI GT62VR 6RD Dominator M.2 SSD Replacement
O que você precisa
  1. MSI GT62VR 6RD Dominator M.2 SSD Replacement, M.2 SSD: passo 1, imagem 1 %32 MSI GT62VR 6RD Dominator M.2 SSD Replacement, M.2 SSD: passo 1, imagem 2 %32
    • Remove the six 1.2mm screws on the bottom plate of the laptop using a JIS #0 screwdriver.
  2. MSI GT62VR 6RD Dominator M.2 SSD Replacement: passo 2, imagem 1 %32 MSI GT62VR 6RD Dominator M.2 SSD Replacement: passo 2, imagem 2 %32 MSI GT62VR 6RD Dominator M.2 SSD Replacement: passo 2, imagem 3 %32
    • Insert the plastic opening tool into the seam on the backplate of the laptop.
    • A popping sound will be produced from your device while you remove the backplate.
    • Pry the back plate up.
    • Slide the plastic opening tool around the laptop's edge slowly until the backplate is completely removed.
  3. MSI GT62VR 6RD Dominator M.2 SSD Replacement: passo 3, imagem 1 %32 MSI GT62VR 6RD Dominator M.2 SSD Replacement: passo 3, imagem 2 %32
    • Remove the single 1.2mm screw securing the SSD to the laptop using the JIS #0 screwdriver.
  4. MSI GT62VR 6RD Dominator M.2 SSD Replacement: passo 4, imagem 1 %32 MSI GT62VR 6RD Dominator M.2 SSD Replacement: passo 4, imagem 2 %32
    • Remove the old SSD, then insert and screw in the new one.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
Isn’t that an M.2 Drive not a GPU? the GPU is in the top right. under the heat pipes.
Will Rogers - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 1,265
