Ir para o conteúdo principal
MSI GT62VR 6RD Dominator Hard Drive Replacement
O que você precisa
  1. MSI GT62VR 6RD Dominator Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 MSI GT62VR 6RD Dominator Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32
    • Remove the six screws on the back plate of the laptop using a JIS #0 screwdriver.
  2. MSI GT62VR 6RD Dominator Hard Drive Replacement: passo 2, imagem 1 %32 MSI GT62VR 6RD Dominator Hard Drive Replacement: passo 2, imagem 2 %32 MSI GT62VR 6RD Dominator Hard Drive Replacement: passo 2, imagem 3 %32
    • Insert a plastic opening tool into the seam of the back cover
    • Pry the cover up until clips release.
    • Slide the plastic opening tool around the laptop until cover is fully removed.
  3. MSI GT62VR 6RD Dominator Hard Drive Replacement: passo 3, imagem 1 %32 MSI GT62VR 6RD Dominator Hard Drive Replacement: passo 3, imagem 2 %32
    • Remove the two screws securing the hard drive to the laptop.
    • Lightly lift the hard drive up by grasping the silver bracket that secures it to the laptop.
    • Wiggle it backwards slowly until it is unplugged.
    • Slide out from under the cover towards the battery.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 660
