Ir para o conteúdo principal
MSI GT62VR 6RD Dominator Cooling Fan Replacement
O que você precisa
  1. MSI GT62VR 6RD Dominator Cooling Fan Replacement, Cooling Fan: passo 1, imagem 1 %32 MSI GT62VR 6RD Dominator Cooling Fan Replacement, Cooling Fan: passo 1, imagem 2 %32
    • Remove the six 1.2mm screws on the bottom plate of the laptop using a JIS #0 screwdriver.
  2. MSI GT62VR 6RD Dominator Cooling Fan Replacement: passo 2, imagem 1 %32 MSI GT62VR 6RD Dominator Cooling Fan Replacement: passo 2, imagem 2 %32 MSI GT62VR 6RD Dominator Cooling Fan Replacement: passo 2, imagem 3 %32
    • Insert the plastic opening tools into the seam on the back plate of the laptop.
    • A popping sound may come from your device while you remove the backplate.
    • Pry the back plate up.
    • Slide the plastic opening tool around the laptop's edge slowly until the backplate is completely removed.
  3. MSI GT62VR 6RD Dominator Cooling Fan Replacement: passo 3, imagem 1 %32 MSI GT62VR 6RD Dominator Cooling Fan Replacement: passo 3, imagem 2 %32
    • Remove the three 2.0mm screws using the JIS #0 screwdriver.
  4. MSI GT62VR 6RD Dominator Cooling Fan Replacement: passo 4, imagem 1 %32 MSI GT62VR 6RD Dominator Cooling Fan Replacement: passo 4, imagem 2 %32
    • The white plastic clip secures the fan wires to the laptop.
    • Unplug the white clip by grasping it and wiggling it back and forth .
    • Do not pull the clip out by the wires themselves.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 1,561
