Ir para o conteúdo principal
MSI GT62VR 6RD Dominator Battery Replacement
O que você precisa
  1. MSI GT62VR 6RD Dominator Battery Replacement, Battery: passo 1, imagem 1 %32 MSI GT62VR 6RD Dominator Battery Replacement, Battery: passo 1, imagem 2 %32
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the 6 screws on the bottom plate of the laptop using a Phillips driver.
  2. MSI GT62VR 6RD Dominator Battery Replacement: passo 2, imagem 1 %32 MSI GT62VR 6RD Dominator Battery Replacement: passo 2, imagem 2 %32
    • Insert the plastic opening tool into the back plate of the laptop and lightly pry it up.
    • The laptop cover will break if it is being handled roughly.
    • Slide the plastic opening tool around the laptop's edge gently, slowly popping off the clips securing it into the laptop.
    • Remove the back plate.
  3. MSI GT62VR 6RD Dominator Battery Replacement: passo 3, imagem 1 %32 MSI GT62VR 6RD Dominator Battery Replacement: passo 3, imagem 2 %32 MSI GT62VR 6RD Dominator Battery Replacement: passo 3, imagem 3 %32
    • Locate the battery.
    • The wires are located at the back end of the battery and covered in tape.
    • Remove the tape covering the battery connector.
    • Place your hands at the corners of the wires.
    • Pull upward from the back end of the battery where the wires are located.
    • Remove the battery.
Conclusão
Rebekah Johnson
Membro desde: 09/18/18
147 Reputação
Autoria de 1 guia
Um comentário
Can i use it using chargine cable even if i remove rhe battery?
Tabs XXIV - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 1,953
