Ir para o conteúdo principal
MSI GS70 Hard Drive Replacement
O que você precisa
  1. MSI GS70 Hard Drive Replacement, Remove the Backplate: passo 1, imagem 1 %32 MSI GS70 Hard Drive Replacement, Remove the Backplate: passo 1, imagem 2 %32
    • Using your JIS #1, locate and remove all screws from the backplate.
    • When all the screws are removed, proceed to remove the backplate. The hard drive will be located right next to the battery.
  2. MSI GS70 Hard Drive Replacement, Remove the Hard Drive Spacer: passo 2, imagem 1 %32 MSI GS70 Hard Drive Replacement, Remove the Hard Drive Spacer: passo 2, imagem 2 %32
    • Locate the black rubber spacer
    • Remove the spacer by gently pulling the flap
  3. MSI GS70 Hard Drive Replacement, Disconnect your Hard Drive: passo 3, imagem 1 %32
    • With two hands slide the Hard Drive to the left.
  4. MSI GS70 Hard Drive Replacement, Remove the Hard Drive: passo 4, imagem 1 %32 MSI GS70 Hard Drive Replacement, Remove the Hard Drive: passo 4, imagem 2 %32
    • Carfully lift up the Hard Drive using your Spudger.
    • Next, pull up your hard drive from the battery end and proceed to remove the hard drive
Conclusão
11 outras pessoas executaram este guia.
Matthew Tasker
Membro desde: 04/16/10
377 Reputação
Autoria de 1 guia
2 comentários
The screws on my machine were Philips not torx don't know if it is different or has changed at all but all internal and external were Phillips
rambo33hockey - Responder
bonjour
comment accéder au disque dur msata sur le msi gs 70
Vivabzh côtes d'armors - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 31
Duração total: 16,230
