Ir para o conteúdo principal
MSI GS70 Battery Replacement
O que você precisa
  1. MSI GS70 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Make sure that the laptop is turned off before starting.
    • Place laptop with the bottom plate facing up.
  2. MSI GS70 Battery Replacement: passo 2, imagem 1 %32
    • Remove all screws using the JIS #1 screwdriver.
    2 more screws right in the middle not marked in the pic. remember to get the one under the warranty sticker
    Dave D - Responder
  3. MSI GS70 Battery Replacement: passo 3, imagem 1 %32
    • Remove the back plate.
    • Locate the battery.
  4. MSI GS70 Battery Replacement: passo 4, imagem 1 %32
    • Locate the foil connector above the battery.
  5. MSI GS70 Battery Replacement: passo 5, imagem 1 %32
    • Flip up both black clips with your spudger.
  6. MSI GS70 Battery Replacement: passo 6, imagem 1 %32
    • Remove the foil connector by pulling on the blue tabs.
  7. MSI GS70 Battery Replacement: passo 7, imagem 1 %32
    • After the foil connector is removed you will see an 8 pin connector.
    • Disconnect the 8 Pin connector.
  8. MSI GS70 Battery Replacement: passo 8, imagem 1 %32
    • Lift the battery and remove.
Conclusão
10 outras pessoas executaram este guia.
3 comentários
Anyone know what the foil connector is? Mine is broken, and needs to be replaced.
Jonathan Hawkes - Responder
Which battery model should I buy?
slackware2007 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 12
Últimos 30 dias: 37
Duração total: 8,901
