Introdução
The RAM is an essential component in a PC that determines how quickly your device will operate. A device will include two RAM sticks that can deteriorate due to age or usage. This can cause your device to slow down overtime and not operate as efficiently as it used to. This guide shows how to replace the RAM on your laptop to improve performance and provide the PC with more power.
O que você precisa
Remove the fifteen black 6.0 mm Phillips #00 screws from the back cover.
Carefully remove the back cover.
4 outras pessoas executaram este guia.
