Introdução
RAM effects the total memory and speed of a laptop. If your RAM is faulty, you will need a lot of patience for it to always be slow. However, if you replace it, like this guide tells you to, your device will perform much better.
O que você precisa
Use the spudger to separate the back plate from the rest of the computer with the screen up like in the picture.
Once the back plate is loose, close the screen for an easier time properly removing it.
Using a Phillips Head #1 screwdriver, unscrew the 15 screws on the bottom of the device
After all the screws are unscrewed, remove the bottom plate. If this is the first time that you are removing this back cover, the last screw is hidden under the "factory seal" label. You will need to break that label to reach that screw.
First locate the speaker(s).
Use the tweezers to lift the speaker from its position.
Grab the multi-colored wire with the tweezers and gently pull back until the speakers releases from its socket.
First, locate all the ribbon cables that are connected to the motherboard.
Lift the ribbon cable connector tabs with the spudger gently.
Using the tweezers, gently pull back on the ribbon cable until it is completely out of the socket.
Use the spudger to lift the motherboard up and remove it from the laptop, then flip the now separated motherboard over.
Using tweezers, disconnect the red wire circled in the picture; where the hard drive would be.
Locate the SSD and the screw holding it in.
Unscrew the one Screw using a #1 Phillips Head screwdriver.
The SSD will want to lift with that screw being removed, from here grab it and pull it out gently.
Locate the RAM.
Pull back the two tabs holding it into place, it will pop out.
Pull it out.
13 outras pessoas executaram este guia.
4 comentários
Super helpful. Thanks.
Thanks, it works on my gs63 8re with minor adjustments (no need to move the speakers)
Great guide! I used this guide to replace the GPU and CPU fans since one has to remove the mobo in order to do so.
Which screws go where?
