Introdução
Is the hard drive malfunctioning when saving files? If so, this hard drive guide will allow you to remove the hard drive.
O que você precisa
Ferramenta utilizada nesse passo:Tweezers$4.99
Unscrew the 15 screws on the bottom panel using a Phillips #00 screwdriver.
Pry open the back cover with a plastic prying tool.
