Ir para o conteúdo principal
MSI GS60 Ghost Pro 4K Gold Edition Wi-Fi Card Replacement
O que você precisa
  1. MSI GS60 Ghost Pro 4K Gold Edition Wi-Fi Card Replacement, Back Panel: passo 1, imagem 1 %32
    • Place this device back panel facing up.
  2. MSI GS60 Ghost Pro 4K Gold Edition Wi-Fi Card Replacement: passo 2, imagem 1 %32
    • Using the screwdriver, unscrew the highlighted 1.2mm Phillips head #0 screws which secure the back panel into place.
  3. MSI GS60 Ghost Pro 4K Gold Edition Wi-Fi Card Replacement: passo 3, imagem 1 %32 MSI GS60 Ghost Pro 4K Gold Edition Wi-Fi Card Replacement: passo 3, imagem 2 %32
    • Using the plastic opening tools, separate the back panel from the rest of the device.
    • Do this by firmly pressing the head of the tool into the space between the back panel, and the rest of the device.
  4. MSI GS60 Ghost Pro 4K Gold Edition Wi-Fi Card Replacement, Wi-Fi Card: passo 4, imagem 1 %32
    • Use the screwdriver to unscrew the 0.5mm Phillips #0 screw holding the Wi-Fi card in place.
  5. MSI GS60 Ghost Pro 4K Gold Edition Wi-Fi Card Replacement: passo 5, imagem 1 %32
    • Take out the Wi-Fi card.
    • Replace the faulty Wi-Fi card with a new Wi-Fi card.
Conclusão
Jordan Williams
Membro desde: 10/19/17
201 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S2-G2, Julie Fall 2017 Membro de UMass Dartmouth, Team S2-G2, Julie Fall 2017
UMASSD-JULIE-F17S2G2
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 571
