Introdução
This guide will instruct you on how to remove the motherboard from your device.
O que você precisa
Unscrew the 4 1.2mm Phillips #0 screws connecting the motherboard to the laptop case.
Disconnect the wires connecting to the motherboard to the USB ports.
Disconnect the ribbon cables connecting the keyboard, and track pad of the device.
2 comentários
How to proceed with a keyboard replacement?
Had a water spill, some keys not working anymore, could this be fixable by a keyboard swap?
Can this be a n IC damage?
