Ir para o conteúdo principal
MSI GS60 Ghost Pro 4K Gold Edition Battery Replacement
O que você precisa
  1. MSI GS60 Ghost Pro 4K Gold Edition Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • Place this device back panel facing up.
  2. MSI GS60 Ghost Pro 4K Gold Edition Battery Replacement: passo 2, imagem 1 %32
    • Using the screwdriver, unscrew the highlighted 1.2mm Phillips head #0 screws which secure the back panel into place.
  3. MSI GS60 Ghost Pro 4K Gold Edition Battery Replacement: passo 3, imagem 1 %32 MSI GS60 Ghost Pro 4K Gold Edition Battery Replacement: passo 3, imagem 2 %32
    • Using the plastic opening tools, separate the back panel from the rest of the device.
    • Do this by firmly pressing the head of the tool into the space between the back panel, and the rest of the device.
  4. MSI GS60 Ghost Pro 4K Gold Edition Battery Replacement, Battery: passo 4, imagem 1 %32
    • Pull the back panel off.
  5. MSI GS60 Ghost Pro 4K Gold Edition Battery Replacement: passo 5, imagem 1 %32
    • Notice the L-shaped battery in the lower right corner of the opened laptop.
    • Disconnect the battery from the slot it is connected to. You'll need to push on the sides of the clip and pull.
  6. MSI GS60 Ghost Pro 4K Gold Edition Battery Replacement: passo 6, imagem 1 %32 MSI GS60 Ghost Pro 4K Gold Edition Battery Replacement: passo 6, imagem 2 %32
    • Lift up the battery with your fingers and remove it from the laptop.
    • Place the battery away from the laptop in a safe spot and insert your new battery by hooking it up to the slot you previously disconnected the old battery from.
Conclusão
Uma outra pessoa concluiu este guia.
Stephen Felix
Membro desde: 10/20/17
207 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S2-G2, Julie Fall 2017 Membro de UMass Dartmouth, Team S2-G2, Julie Fall 2017
UMASSD-JULIE-F17S2G2
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 1,043
