Introdução
This replacement guide is difficult only because in order to replace the RAM, the motherboard need to be taken out of the device completely. However, replacing the RAM itself is not hard at all. so basically all the hard work is to unplug the motherboard completely and take it out to reach the RAM.
O que você precisa
Remove the eleven 5mm screws with a Phillips #0 bit.
Remove the four 2.5mm screws with a Phillips #0 bit.
After unplugging all of the cables and unscrewing all of the screws, gently remove the motherboard out of the computer chassis
This part will take some effort but remember not to apply to much pressure on the motherboard as to not damage any of the small electrical components on the board
After removing the motherboard from the laptop chassis locate the RAM chips indicated by the red rectangle.
3 outras pessoas executaram este guia.
Um comentário
Thank you very much for this guide. I’ve successfully managed to replace my RAM with 16GB module.
