Ir para o conteúdo principal
MSI GP62MVR 6RF Leopard Pro Speakers Replacement
O que você precisa
  1. MSI GP62MVR 6RF Leopard Pro Speakers Replacement, Bottom Cover: passo 1, imagem 1 %32 MSI GP62MVR 6RF Leopard Pro Speakers Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Place the laptop upside down.
    • Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
  2. MSI GP62MVR 6RF Leopard Pro Speakers Replacement: passo 2, imagem 1 %32 MSI GP62MVR 6RF Leopard Pro Speakers Replacement: passo 2, imagem 2 %32
    • Use the Jimmy tool to evenly pry loose the bottom cover.
    • Ensure that all sides are detached from the plastic hinging before attempting to remove the bottom cover.
  3. MSI GP62MVR 6RF Leopard Pro Speakers Replacement: passo 3, imagem 1 %32
    • Remove the back cover.
    • Touching circuitry could damage components or result in personal shock; it is recommended that you now wear latex gloves to prevent both issues.
  4. MSI GP62MVR 6RF Leopard Pro Speakers Replacement, Speakers: passo 4, imagem 1 %32
    • Reorient the computer, if necessary, with a 180 degree turn so that the speakers face you.
  5. MSI GP62MVR 6RF Leopard Pro Speakers Replacement: passo 5, imagem 1 %32
    • On the front panel near the right speaker, there is a connection from the motherboard to the speakers.
    • Detach the white and black wiring from the clip.
  6. MSI GP62MVR 6RF Leopard Pro Speakers Replacement: passo 6, imagem 1 %32
    • Peel back the electrical tape holding the speaker wire in place.
    • Remove the speakers from the front panel, pulling upward.
    • Note that the screws holding the two speakers down were already removed during the bottom cover removal.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 312
