Introdução
This guide demonstrates how to replace the Random Access Memory (RAM) in the MSI GP62MVR 6RF Leopard Pro laptop. It is a simple process with no special skills required. Avoid touching the circuitry when the case is open to avoid short-circuiting components or shocking yourself. If your laptop cannot turn on or fails to run programs, then the RAM will need to be replaced. Follow this guide to change the RAM in a MSI GP62MVR 6RF Leopard Pro.
O que você precisa
Place the laptop upside down.
Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
