Ir para o conteúdo principal
MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement
O que você precisa
  1. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32
    • Using the Jimmy tool, pry the front cover off at the seam.
    • The Jimmy tool is the utensil in the first picture in the user's hand.
  2. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: passo 2, imagem 1 %32 MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: passo 2, imagem 2 %32
    • Remove the four 2 mm screws on the bottom and top corners of the screen using a Phillips #0 screwdriver.
  3. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: passo 3, imagem 1 %32
    • Using the Jimmy, pry off the unscrewed LCD display.
    • Make sure the black adhesive is out of the way.
    • Don't pull the screen completely off, as the screen will still be attached.
  4. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: passo 4, imagem 1 %32 MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: passo 4, imagem 2 %32
    • Remove the ribbon cable by pulling on the bar code tab.
Conclusão
3 comentários
Hey Jordan, when reassembling the front cover (which in my case, a GP63 Leopard 8RE, is glued at the bottom) what type of glue should be used? Thanks
Jaime Blasco - Responder
Hi Jaime, two part expoxy (Alraldite) glue should work, otherwise 3M double-sided adhesive tape would work as well.
Jordan Buck -
Hi Jordan,
If the screen is damaged due to the cover itself being bent, do you have any advice?
Thanks
Ainsley - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 25
Duração total: 1,375
