Ir para o conteúdo principal
MSI GP62MVR 6RF Leopard Pro Fans Replacement
O que você precisa
  1. MSI GP62MVR 6RF Leopard Pro Fans Replacement, Bottom Cover: passo 1, imagem 1 %32 MSI GP62MVR 6RF Leopard Pro Fans Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Place the laptop upside down.
    • Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
  2. MSI GP62MVR 6RF Leopard Pro Fans Replacement: passo 2, imagem 1 %32 MSI GP62MVR 6RF Leopard Pro Fans Replacement: passo 2, imagem 2 %32
    • Use the Jimmy tool to evenly pry loose the bottom cover.
    • Ensure that all sides are detached from the plastic hinging before attempting to remove the bottom cover.
  3. MSI GP62MVR 6RF Leopard Pro Fans Replacement: passo 3, imagem 1 %32
    • Remove the back cover.
    • Touching circuitry could damage components or result in personal shock; it is recommended that you now wear latex gloves to prevent both issues.
  4. MSI GP62MVR 6RF Leopard Pro Fans Replacement, Fans: passo 4, imagem 1 %32 MSI GP62MVR 6RF Leopard Pro Fans Replacement, Fans: passo 4, imagem 2 %32
    • Remove the eight 4.5 mm screws that hold the heat sink to the motherboard with a Phillips #0 screwdriver.
    • Remove the four 4.5 mm screws holding the fan in place also using a Phillips #0 screwdriver.
    • Watch for the screw hidden under the wires highlighted in the second picture.
  5. MSI GP62MVR 6RF Leopard Pro Fans Replacement: passo 5, imagem 1 %32 MSI GP62MVR 6RF Leopard Pro Fans Replacement: passo 5, imagem 2 %32
    • Disconnect both power cables for the fans.
    • Make sure to pinch the power cables. It may require a bit of force.
  6. MSI GP62MVR 6RF Leopard Pro Fans Replacement: passo 6, imagem 1 %32 MSI GP62MVR 6RF Leopard Pro Fans Replacement: passo 6, imagem 2 %32 MSI GP62MVR 6RF Leopard Pro Fans Replacement: passo 6, imagem 3 %32
    • Using the Jimmy tool, remove the adhesive pads securing the fans to the board.
  7. MSI GP62MVR 6RF Leopard Pro Fans Replacement: passo 7, imagem 1 %32
    • Remove the black adhesive.
  8. MSI GP62MVR 6RF Leopard Pro Fans Replacement: passo 8, imagem 1 %32
    • Separate the heat sink from the tab on the side holding the fan in place.
  9. MSI GP62MVR 6RF Leopard Pro Fans Replacement: passo 9, imagem 1 %32
    • Remove the three 3.5 mm screws on each fan holding the fan to the heat sink using a Phillips #0 screwdriver.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 23
Duração total: 1,259
