Ir para o conteúdo principal
MSI GP62MVR 6RF Leopard Pro Battery Replacement
O que você precisa
  1. MSI GP62MVR 6RF Leopard Pro Battery Replacement, Bottom Cover: passo 1, imagem 1 %32 MSI GP62MVR 6RF Leopard Pro Battery Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Place the laptop upside down.
    • Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
  2. MSI GP62MVR 6RF Leopard Pro Battery Replacement: passo 2, imagem 1 %32 MSI GP62MVR 6RF Leopard Pro Battery Replacement: passo 2, imagem 2 %32
    • Use the Jimmy tool to evenly pry loose the bottom cover.
    • Ensure that all sides are detached from the plastic hinging before attempting to remove the bottom cover.
  3. MSI GP62MVR 6RF Leopard Pro Battery Replacement: passo 3, imagem 1 %32
    • Remove the back cover.
    • Touching circuitry could damage components or result in personal shock; it is recommended that you now wear latex gloves to prevent both issues.
  4. MSI GP62MVR 6RF Leopard Pro Battery Replacement, Battery: passo 4, imagem 1 %32 MSI GP62MVR 6RF Leopard Pro Battery Replacement, Battery: passo 4, imagem 2 %32 MSI GP62MVR 6RF Leopard Pro Battery Replacement, Battery: passo 4, imagem 3 %32
    • Using a Phillips #0 Screwdriver, remove the single 5.5 mm screw fastening the battery to the body of the computer.
    • Remove the battery from the device.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 30
Duração total: 1,260
