Ir para o conteúdo principal
MSI GP60 2PE Leopard Hard Drive Replacement
O que você precisa
  1. MSI GP60 2PE Leopard Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Flip MSI GP60 2PE Leopard, so that the back is facing up.
  2. MSI GP60 2PE Leopard Hard Drive Replacement: passo 2, imagem 1 %32
    • Find the unlock tab located on the upper right side of the device, then slide it to the right.
  3. MSI GP60 2PE Leopard Hard Drive Replacement: passo 3, imagem 1 %32 MSI GP60 2PE Leopard Hard Drive Replacement: passo 3, imagem 2 %32 MSI GP60 2PE Leopard Hard Drive Replacement: passo 3, imagem 3 %32
    • Slide and hold the release tab on the left side of the battery, so that you can remove the battery.
  4. MSI GP60 2PE Leopard Hard Drive Replacement: passo 4, imagem 1 %32 MSI GP60 2PE Leopard Hard Drive Replacement: passo 4, imagem 2 %32 MSI GP60 2PE Leopard Hard Drive Replacement: passo 4, imagem 3 %32
    • While holding the release tab, remove the battery slowly.
  5. MSI GP60 2PE Leopard Hard Drive Replacement, Back Panel: passo 5, imagem 1 %32
    • Flip the device over so the back is facing up.
  6. MSI GP60 2PE Leopard Hard Drive Replacement: passo 6, imagem 1 %32 MSI GP60 2PE Leopard Hard Drive Replacement: passo 6, imagem 2 %32
    • Remove the four 5mm screws from the back of the device using a Phillips #00 screwdriver.
    • There is a screw located under the battery; lift the battery up to access it.
  7. MSI GP60 2PE Leopard Hard Drive Replacement: passo 7, imagem 1 %32 MSI GP60 2PE Leopard Hard Drive Replacement: passo 7, imagem 2 %32
    • Once all four screws are removed, lift the back off.
  8. MSI GP60 2PE Leopard Hard Drive Replacement, Hard Drive: passo 8, imagem 1 %32
    • Remove the two 5 mm black screws on the right hand side with a Phillips #0 screwdriver.
  9. MSI GP60 2PE Leopard Hard Drive Replacement: passo 9, imagem 1 %32 MSI GP60 2PE Leopard Hard Drive Replacement: passo 9, imagem 2 %32 MSI GP60 2PE Leopard Hard Drive Replacement: passo 9, imagem 3 %32
    • Lift the hard drive, then remove from the device. There is a black strip of plastic attached to make the process easier.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 19
Duração total: 1,381
