Ir para o conteúdo principal
MSI GE72 6QF Apache Pro SSD Replacement
O que você precisa
  1. MSI GE72 6QF Apache Pro SSD Replacement, Battery: passo 1, imagem 1 %32 MSI GE72 6QF Apache Pro SSD Replacement, Battery: passo 1, imagem 2 %32
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro SSD Replacement: passo 2, imagem 1 %32
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro SSD Replacement: passo 3, imagem 1 %32
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro SSD Replacement: passo 4, imagem 1 %32 MSI GE72 6QF Apache Pro SSD Replacement: passo 4, imagem 2 %32
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro SSD Replacement: passo 5, imagem 1 %32 MSI GE72 6QF Apache Pro SSD Replacement: passo 5, imagem 2 %32
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro SSD Replacement: passo 6, imagem 1 %32 MSI GE72 6QF Apache Pro SSD Replacement: passo 6, imagem 2 %32
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro SSD Replacement, SSD: passo 7, imagem 1 %32 MSI GE72 6QF Apache Pro SSD Replacement, SSD: passo 7, imagem 2 %32
    • Remove the single 5.5mm Phillips #1 screw attaching the SSD to the laptop.
  8. MSI GE72 6QF Apache Pro SSD Replacement: passo 8, imagem 1 %32 MSI GE72 6QF Apache Pro SSD Replacement: passo 8, imagem 2 %32
    • Pull out the SSD by gently wiggling it from side to side until it comes out.
    • If the old SSD you removed contains the operating system, then the new SSD must also contain an operating system.
Conclusão
7 outras pessoas executaram este guia.
Tanmay Kumar
Membro desde: 04/17/17
458 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S14-G4, Banghart Spring 2017 Membro de Cal Poly, Team S14-G4, Banghart Spring 2017
CPSU-BANGHART-S17S14G4
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 41
Duração total: 7,760
