Ir para o conteúdo principal
MSI GE72 6QF Apache Pro RAM Replacement
O que você precisa
  1. MSI GE72 6QF Apache Pro RAM Replacement, Battery: passo 1, imagem 1 %32 MSI GE72 6QF Apache Pro RAM Replacement, Battery: passo 1, imagem 2 %32
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro RAM Replacement: passo 2, imagem 1 %32
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro RAM Replacement: passo 3, imagem 1 %32
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro RAM Replacement: passo 4, imagem 1 %32 MSI GE72 6QF Apache Pro RAM Replacement: passo 4, imagem 2 %32
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro RAM Replacement: passo 5, imagem 1 %32 MSI GE72 6QF Apache Pro RAM Replacement: passo 5, imagem 2 %32
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro RAM Replacement: passo 6, imagem 1 %32 MSI GE72 6QF Apache Pro RAM Replacement: passo 6, imagem 2 %32
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro RAM Replacement, RAM: passo 7, imagem 1 %32 MSI GE72 6QF Apache Pro RAM Replacement, RAM: passo 7, imagem 2 %32
    • When you open the back cover, the RAM will be located as shown in the picture.
  8. MSI GE72 6QF Apache Pro RAM Replacement: passo 8, imagem 1 %32 MSI GE72 6QF Apache Pro RAM Replacement: passo 8, imagem 2 %32 MSI GE72 6QF Apache Pro RAM Replacement: passo 8, imagem 3 %32
    • Press the hinges on the sides of the RAM chip as shown in the picture, in order to unlock it.
    • Carefully, slide it out at a 45 degree angle.
    • Don't press on the hinges too hard.
    • Be careful about the angle at which you're sliding out the chip.
  9. MSI GE72 6QF Apache Pro RAM Replacement: passo 9, imagem 1 %32 MSI GE72 6QF Apache Pro RAM Replacement: passo 9, imagem 2 %32 MSI GE72 6QF Apache Pro RAM Replacement: passo 9, imagem 3 %32
    • Similarly, press on the hinges on the sides of the other RAM chip, in order to unlock it.
    • Some laptop models might not come with two RAM chips, so if that is your case, you can skip this step.
Conclusão
Uma outra pessoa concluiu este guia.
Tanmay Kumar
Membro desde: 04/17/17
458 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S14-G4, Banghart Spring 2017 Membro de Cal Poly, Team S14-G4, Banghart Spring 2017
CPSU-BANGHART-S17S14G4
Membros da 4
Autoria de 8 guias
Um comentário
Can you put more ram in this laptop like 32gb?
Can you put another ssd?
nojus.zibikas - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 18
Duração total: 4,649
