Ir para o conteúdo principal
MSI GE72 6QF Apache Pro Optical Drive Replacement
O que você precisa
  1. MSI GE72 6QF Apache Pro Optical Drive Replacement, Battery: passo 1, imagem 1 %32 MSI GE72 6QF Apache Pro Optical Drive Replacement, Battery: passo 1, imagem 2 %32
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro Optical Drive Replacement: passo 2, imagem 1 %32
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro Optical Drive Replacement: passo 3, imagem 1 %32
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro Optical Drive Replacement: passo 4, imagem 1 %32 MSI GE72 6QF Apache Pro Optical Drive Replacement: passo 4, imagem 2 %32
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro Optical Drive Replacement: passo 5, imagem 1 %32 MSI GE72 6QF Apache Pro Optical Drive Replacement: passo 5, imagem 2 %32
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro Optical Drive Replacement: passo 6, imagem 1 %32 MSI GE72 6QF Apache Pro Optical Drive Replacement: passo 6, imagem 2 %32
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: passo 7, imagem 1 %32 MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: passo 7, imagem 2 %32 MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: passo 7, imagem 3 %32
    • Carefully slide the Optical Drive off of the SATA connector.
    • The red marker shows the location for where the retaining screw comes through the back panel to hold the Optical Drive.
Conclusão
Uma outra pessoa concluiu este guia.
2 comentários
Why do you have to remove the battery first?
Kevin - Responder
So you don’t have power running through it while working on it.
croberts1290 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 1,463
