Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will show you how to replace the fans in your MSI GE72 6QF Apache Pro.
O que você precisa
With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
Use a Phillips #1 screwdriver to remove the ten 5.5mm screws.
Remove the last two 5.5mm Phillips #1 screws, and remove the washers around them.
19 outras pessoas executaram este guia.
9 comentários
I can't get the back case off the last bit of it is held on pretty tight. All the screws are out so how do I loosen it?
Where can I buy new fans?
Where do you buy the replacement fans
I need a link to buy the actual fan itself if you wouldn’t mind I’d greatly appreciate it
EDIT: The only place I could actually find the fans were on walmart so Ill post the link here -> https://www.walmart.com/search/?query=ms... (I personally bought the blue one that was first I should get it by next friday and Ill try and remember to post if it works or not)
