Ir para o conteúdo principal
MSI GE72 6QF Apache Pro Battery Replacement
O que você precisa
  1. MSI GE72 6QF Apache Pro Battery Replacement, Battery: passo 1, imagem 1 %32 MSI GE72 6QF Apache Pro Battery Replacement, Battery: passo 1, imagem 2 %32
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro Battery Replacement: passo 2, imagem 1 %32
    • Slide the optical drive out of the laptop.
    Good day sir pls am urgently look for the complete cd rom for this laptop msi 1791. Please if u can get some for me text me on 7186034112
    rauffsulemane - Responder
    Or send me and email rauff191@gmail.com
  3. MSI GE72 6QF Apache Pro Battery Replacement: passo 3, imagem 1 %32
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro Battery Replacement: passo 4, imagem 1 %32 MSI GE72 6QF Apache Pro Battery Replacement: passo 4, imagem 2 %32
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro Battery Replacement: passo 5, imagem 1 %32 MSI GE72 6QF Apache Pro Battery Replacement: passo 5, imagem 2 %32
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro Battery Replacement: passo 6, imagem 1 %32 MSI GE72 6QF Apache Pro Battery Replacement: passo 6, imagem 2 %32
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
Conclusão
5 outras pessoas executaram este guia.
Hovik Aklyan
Membro desde: 04/19/17
233 Reputação
Autoria de 1 guia
4 comentários
hi there, can we use the laptop without the battery attached? i mean using only the power adaptor straight through the electric plug
San - Responder
yes you can, might drop bit of performance if you have Hybrid power management on, buyed my laptop used its 4 years old now and was used 2 years, dont even checked used battery but removed it and using AC power, just after a while gonna need to replace vents…
also cooling is problem in summers, cut-off some plastics and using cooling pad (recommending with 3+ vents or good airflow)
Ivars Kemers -
Faut démonter TOUTES les vis ??? Je vais en perdre la moitié !
Bravo!! plus simple c’était pas possibles?
Dire qu’avant on avait une trappe coulissante d’acces (DELL) ..
Bruno R - Responder
Les PC portables MSI ne sont pas les pire à réparer, loin de là !
Par expérience, l’étape la plus délicate c’est d’arriver à enlever le capot car il est maintenu par des clips en plastique, après on a accès à pratiquement toutes les pièces sur ce modèle.
Aujourd’hui, les PC portables avec une trappe coulissante existent toujours, mais ils sont cher :)
Brendan -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 62
Duração total: 10,132
