Ir para o conteúdo principal
Introdução
This guide shows how to locate and remove the battery of a MSI GE72 6QF Apache Pro for possible replacement.
  1. Make sure the laptop is off and unplugged (not charging). With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. Slide the optical drive out of the laptop.
    • Slide the optical drive out of the laptop.
  3. Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. Using your fingers, gently loosen the edges of all four sides of the back cover. Gently pull off the back cover.
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure. Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. Grab the battery with your fingers and gently pull it up and away from the rest of the laptop. Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
Conclusão
4 outras pessoas concluíram este guia.
Hovik Aklyan
Membro desde: 19/04/2017
209 Reputação
Autoria de 1 guia
hi there, can we use the laptop without the battery attached? i mean using only the power adaptor straight through the electric plug
San - Responder
yes you can, might drop bit of performance if you have Hybrid power management on, buyed my laptop used its 4 years old now and was used 2 years, dont even checked used battery but removed it and using AC power, just after a while gonna need to replace vents…
also cooling is problem in summers, cut-off some plastics and using cooling pad (recommending with 3+ vents or good airflow)
Ivars Kemers -
Faut démonter TOUTES les vis ??? Je vais en perdre la moitié !
Bravo!! plus simple c’était pas possibles?
Dire qu’avant on avait une trappe coulissante d’acces (DELL) ..
Bruno R - Responder
Les PC portables MSI ne sont pas les pire à réparer, loin de là !
Par expérience, l’étape la plus délicate c’est d’arriver à enlever le capot car il est maintenu par des clips en plastique, après on a accès à pratiquement toutes les pièces sur ce modèle.
Aujourd’hui, les PC portables avec une trappe coulissante existent toujours, mais ils sont cher :)
Brendan -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 31
Últimos 30 dias: 111
Duração total: 6,573
