Ferramentas
Peças
Nenhum componente especificado.
Highlighted in red are a set of cords you have to unplug. Simply do so in order to remove the fan.
The screws here have washers you need to remove as well.
The rest of the screws, highlighted in yellow are just normal PH#1 screws.
Once all the screws are removed and the wires are unplugged, carefully lift the fan out of the laptop.
Finally, we will remove the motherboard for replacement. Highlighted in yellow are the screw we will need to be removing.
Here, highlighted in red are a series of plugs you will have to remove. Once you have completely detached the motherboard from any remaining items, carefully pull it out.
2 outras pessoas concluíram este guia.
2 comentários
This was done thoroughly and clearly. Wonderful job!
Very helpful. Thanks
