Ir para o conteúdo principal
MSI GE62 Apache Pro 004 Web Camera Replacement
O que você precisa
  1. MSI GE62 Apache Pro 004 Web Camera Replacement, Battery: passo 1, imagem 1 %32
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Web Camera Replacement: passo 2, imagem 1 %32 MSI GE62 Apache Pro 004 Web Camera Replacement: passo 2, imagem 2 %32
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Web Camera Replacement: passo 3, imagem 1 %32 MSI GE62 Apache Pro 004 Web Camera Replacement: passo 3, imagem 2 %32 MSI GE62 Apache Pro 004 Web Camera Replacement: passo 3, imagem 3 %32
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Web Camera Replacement, Web Camera: passo 4, imagem 1 %32
    • Flip over the laptop and open it.
  5. MSI GE62 Apache Pro 004 Web Camera Replacement: passo 5, imagem 1 %32 MSI GE62 Apache Pro 004 Web Camera Replacement: passo 5, imagem 2 %32 MSI GE62 Apache Pro 004 Web Camera Replacement: passo 5, imagem 3 %32
    • Slide a metal opener tool along the outside edges of the front screen panel to start to separate it from the back screen panel.
    • You may need to apply some firm pressure to get it started.
  6. MSI GE62 Apache Pro 004 Web Camera Replacement: passo 6, imagem 1 %32 MSI GE62 Apache Pro 004 Web Camera Replacement: passo 6, imagem 2 %32
    • Once it has started to separate, gently pull off the screen panel by working along the edge, and set it aside.
  7. MSI GE62 Apache Pro 004 Web Camera Replacement: passo 7, imagem 1 %32 MSI GE62 Apache Pro 004 Web Camera Replacement: passo 7, imagem 2 %32
    • Locate the WebCam on the middle of the device.
    • Slide a metal opener tool to remove the Webcam
Conclusão
Majid Al Hashmi
Membro desde: 02/13/18
283 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S15-G5, Boczar Spring 2018 Membro de USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 821
