Ir para o conteúdo principal
MSI GE62 Apache Pro 004 Speakers Replacement
O que você precisa
  1. MSI GE62 Apache Pro 004 Speakers Replacement, Battery: passo 1, imagem 1 %32
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Speakers Replacement: passo 2, imagem 1 %32 MSI GE62 Apache Pro 004 Speakers Replacement: passo 2, imagem 2 %32
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Speakers Replacement: passo 3, imagem 1 %32 MSI GE62 Apache Pro 004 Speakers Replacement: passo 3, imagem 2 %32 MSI GE62 Apache Pro 004 Speakers Replacement: passo 3, imagem 3 %32
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: passo 4, imagem 1 %32 MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: passo 4, imagem 2 %32 MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: passo 4, imagem 3 %32
    • Remove the four screws, two on each speaker, with a PH1 screwdriver.
  5. MSI GE62 Apache Pro 004 Speakers Replacement: passo 5, imagem 1 %32 MSI GE62 Apache Pro 004 Speakers Replacement: passo 5, imagem 2 %32
    • Gently pull back the speakers until they release from their socket.
    • Keep track of which speaker went where. The connectors for the speakers are unique; you cannot use a speaker that should go on the right side on the left side and vice versa.
Conclusão
Majid Al Hashmi
Membro desde: 02/13/18
283 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S15-G5, Boczar Spring 2018 Membro de USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 1,516
