Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
Remove the bottom plate
Remove the screw holding down the battery with a PH1 screwdriver.
Pull out the battery.
Open the laptop up as if you were going to use it.
Wedge a spudger in between the screen bezel and work it around to separate it.
Remove the screws holding in the screen at the corners with a PH1 screwdriver.
Remove the bezel from the screen.
Remove the two screws located at the bottom of the screen using the PH1 screwdriver.
