Ir para o conteúdo principal
MSI GE62 Apache Pro 004 Motherboard Replacement
O que você precisa
  1. MSI GE62 Apache Pro 004 Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Motherboard Replacement: passo 2, imagem 1 %32 MSI GE62 Apache Pro 004 Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Motherboard Replacement: passo 3, imagem 1 %32 MSI GE62 Apache Pro 004 Motherboard Replacement: passo 3, imagem 2 %32 MSI GE62 Apache Pro 004 Motherboard Replacement: passo 3, imagem 3 %32
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 MSI GE62 Apache Pro 004 Motherboard Replacement, Motherboard: passo 4, imagem 2 %32
    • Remove the cooling assembly by unscrewing the fourteen screws holding it in place.
  5. MSI GE62 Apache Pro 004 Motherboard Replacement: passo 5, imagem 1 %32 MSI GE62 Apache Pro 004 Motherboard Replacement: passo 5, imagem 2 %32 MSI GE62 Apache Pro 004 Motherboard Replacement: passo 5, imagem 3 %32
    • Remove the speakers holding the motherboard in place, located on the bottom left and bottom right of the device.
    • Unfasten the 8 screws holding the motherboard in place.
    • Pull out the motherboard.
Conclusão
Alexander
Membro desde: 02/19/18
86 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S15-G5, Boczar Spring 2018 Membro de USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
Membros da 4
Autoria de 5 guias
Um comentário
Hi,can i change msi ge62 6qf motherboard with ge62 7rd apache pro?
Its essential for me.tnx.
rahim dargahi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 2,022
