Ir para o conteúdo principal
MSI GE62 6QF Apache Pro Hard Drive Replacement
O que você precisa
  1. MSI GE62 6QF Apache Pro Hard Drive Replacement, Optical Drive: passo 1, imagem 1 %32
    • Use a Phillips screwdriver to remove the 5mm screw securing the optical drive to the bottom case.
  2. MSI GE62 6QF Apache Pro Hard Drive Replacement: passo 2, imagem 1 %32
    • Slide Optical Drive out of the computer.
  3. MSI GE62 6QF Apache Pro Hard Drive Replacement, Bottom Case: passo 3, imagem 1 %32
    • Use a Phillips screwdriver to remove the fourteen 5mm screws on the back of the laptop.
    • One of these screws is hidden under a sticker.
  4. MSI GE62 6QF Apache Pro Hard Drive Replacement: passo 4, imagem 1 %32 MSI GE62 6QF Apache Pro Hard Drive Replacement: passo 4, imagem 2 %32 MSI GE62 6QF Apache Pro Hard Drive Replacement: passo 4, imagem 3 %32
    • Remove the three PH #0 2mm screws that were hidden underneath the optical drive.
  5. MSI GE62 6QF Apache Pro Hard Drive Replacement: passo 5, imagem 1 %32 MSI GE62 6QF Apache Pro Hard Drive Replacement: passo 5, imagem 2 %32
    • Use an opening tool to run along the seam of the case where the upper and bottom case meet.
    • Pry the bottom case and remove from the upper part.
  6. MSI GE62 6QF Apache Pro Hard Drive Replacement, Battery: passo 6, imagem 1 %32 MSI GE62 6QF Apache Pro Hard Drive Replacement, Battery: passo 6, imagem 2 %32 MSI GE62 6QF Apache Pro Hard Drive Replacement, Battery: passo 6, imagem 3 %32
    • Remove the single PH #0 5mm screw holding the battery pack in place.
    • Remove the battery by sliding it away from the computer.
  7. MSI GE62 6QF Apache Pro Hard Drive Replacement, Hard Drive: passo 7, imagem 1 %32 MSI GE62 6QF Apache Pro Hard Drive Replacement, Hard Drive: passo 7, imagem 2 %32 MSI GE62 6QF Apache Pro Hard Drive Replacement, Hard Drive: passo 7, imagem 3 %32
    • Unscrew the two black PH #0 2mm screws holding the lower part the hard drive plate
    • Unscrew the two PH #0 4mm screws holding the upper part of the hard drive plate
  8. MSI GE62 6QF Apache Pro Hard Drive Replacement: passo 8, imagem 1 %32 MSI GE62 6QF Apache Pro Hard Drive Replacement: passo 8, imagem 2 %32
    • Remove the hard drive by gently lifting up and pulling the drive out of the connection slot
Conclusão
5 outras pessoas executaram este guia.
Justice Owens
Membro desde: 09/26/17
604 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S2-G3, Passmore Fall 2017 Membro de USF Tampa, Team S2-G3, Passmore Fall 2017
USFT-PASSMORE-F17S2G3
Membros da 3
Autoria de 5 guias
4 comentários
Saved my life, would have had no idea what to do without these instructions and would probably have broke something. My new 2tb ssd is working fine
Simon Porter - Responder
Upgraded the Memory to 32GB and the HDD to a 1TB SATA SSD.
Prabodha Elangasinha - Responder
Only issue I ran into was one of the optical drive screws was frozen in, stripped hard, and I had to fall back on Moodys to break it loose. Once done, everything else was cake.
Chuck Brewer - Responder
My ssd is working fine and the hdd has gone bad on mine... have not even opened mine yet but looking at the pics I wonder where the second drive is located?
Eric Jimenez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 51
Duração total: 8,239
