Ir para o conteúdo principal
MSI GE62 6QF Apache Pro Battery Replacement
O que você precisa
  1. MSI GE62 6QF Apache Pro Battery Replacement, Optical Drive: passo 1, imagem 1 %32
    • Use a Phillips screwdriver to remove the 5mm screw securing the optical drive to the bottom case.
  2. MSI GE62 6QF Apache Pro Battery Replacement: passo 2, imagem 1 %32
    • Slide Optical Drive out of the computer.
  3. MSI GE62 6QF Apache Pro Battery Replacement, Bottom Case: passo 3, imagem 1 %32
    • Use a Phillips screwdriver to remove the fourteen 5mm screws on the back of the laptop.
    • One of these screws is hidden under a sticker.
  4. MSI GE62 6QF Apache Pro Battery Replacement: passo 4, imagem 1 %32 MSI GE62 6QF Apache Pro Battery Replacement: passo 4, imagem 2 %32 MSI GE62 6QF Apache Pro Battery Replacement: passo 4, imagem 3 %32
    • Remove the three PH #0 2mm screws that were hidden underneath the optical drive.
  5. MSI GE62 6QF Apache Pro Battery Replacement: passo 5, imagem 1 %32 MSI GE62 6QF Apache Pro Battery Replacement: passo 5, imagem 2 %32
    • Use an opening tool to run along the seam of the case where the upper and bottom case meet.
    • Pry the bottom case and remove from the upper part.
  6. MSI GE62 6QF Apache Pro Battery Replacement, Battery: passo 6, imagem 1 %32 MSI GE62 6QF Apache Pro Battery Replacement, Battery: passo 6, imagem 2 %32 MSI GE62 6QF Apache Pro Battery Replacement, Battery: passo 6, imagem 3 %32
    • Remove the single PH #0 5mm screw holding the battery pack in place.
    • Remove the battery by sliding it away from the computer.
Conclusão
4 outras pessoas executaram este guia.
Justice Owens
Membro desde: 09/26/17
604 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S2-G3, Passmore Fall 2017 Membro de USF Tampa, Team S2-G3, Passmore Fall 2017
USFT-PASSMORE-F17S2G3
Membros da 3
Autoria de 5 guias
Um comentário
Excellent guide! Very straightforward with very clear picture. I was able to replace my laptop battery using your tools and following your instruction! 10/10!
Carl Patterson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 45
Duração total: 6,386
