Introdução
In this guide we have a MSI Force GC30 V2, model number/name is MSI Force GC30 V2 and we are replacing the D-Pad (Directional Pad). The D-Pad is a directional controller for the controller itself or it could also be used for various other inputs. The D-Pad may become damaged with prolonged use or rough play. The MSI Force GC30 V2 also has an alternate D-Pad that comes with the controller you can use with this guide. One symptom of a bad D-Pad is no game input when pressing the D-Pad.
O que você precisa
Puncture the sticker where indicated using a screwdriver.
Remove the 9.1 mm-long Phillips #0 screw.
Remove the remaining six 9.2 mm-long Phillips #0 screws with a Philips #0 screwdriver.
Use blunt tweezers to disconnect both of the vibration motor connectors from the motherboard.
Carefully remove both the right and left vibration motors from their housing.
Remove the 7.1 mm-long screw with a Phillips #0 screwdriver.
Remove the 7 mm-long screw with a Phillips #0 screwdriver.
Carefully lift the motherboard out of its housing.
Uma outra pessoa concluiu este guia.
