Ir para o conteúdo principal
MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement
O que você precisa
  1. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement, Faucet: passo 1, imagem 1 %32
    • Turn the water shutoff valve underneath the sink downwards to stop the flow of water.
  2. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 2, imagem 1 %32
    • Turn the tap(s) on to release any pressure build-up in the pipes.
  3. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 3, imagem 1 %32 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 3, imagem 2 %32 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 3, imagem 3 %32
    • With pliers, unscrew the mounting nuts underneath the sink by turning them counterclockwise.
  4. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 4, imagem 1 %32 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 4, imagem 2 %32 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 4, imagem 3 %32
    • With an adjustable wrench, unscrew the bolts connecting the faucet pipes to the supply lines.
    • After unscrewing the bolts, the faucet pipes should easily come off.
  5. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 5, imagem 1 %32 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 5, imagem 2 %32 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 5, imagem 3 %32
    • Disconnect the lift rod for the drain plug by pushing it off the metal rod.
  6. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 6, imagem 1 %32 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 6, imagem 2 %32 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 6, imagem 3 %32
    • After everything is completely disconnected, pull the faucet out from the top.
  7. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 7, imagem 1 %32 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 7, imagem 2 %32 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 7, imagem 3 %32
    • Clean the area in which the replacement faucet will be placed to ensure that there is a flat surface.
  8. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 8, imagem 1 %32 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 8, imagem 2 %32
    • Insert the pipes of the replacement faucet through the sink holes.
    • Each pipe will correspond to each hole on the right and left.
  9. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 9, imagem 1 %32 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 9, imagem 2 %32 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 9, imagem 3 %32
    • With pliers, tighten the mounting nuts underneath the sink in the same location they were removed from.
  10. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 10, imagem 1 %32 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 10, imagem 2 %32 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 10, imagem 3 %32
    • Reattach the faucet pipes to the supply lines and tighten the bolts with an adjustable wrench.
    • Tighten the left and the right pipe.
  11. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 11, imagem 1 %32 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 11, imagem 2 %32 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 11, imagem 3 %32
    • Reattach the lift rod for the drain plug by lining up the holes and pushing it through the metal rod.
  12. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 12, imagem 1 %32 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 12, imagem 2 %32 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 12, imagem 3 %32
    • Turn the shutoff valve upwards to line it up with the pipe and resume the flow of water.
  13. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: passo 13, imagem 1 %32
    • Turn on the tap and inspect for leakage. If any leakage does appear, refer to step 1 & 10 and make the pipe bolts tighter.
    • Otherwise, the replacement sink is completely installed.
Conclusão
To remove the replacement faucet, follow steps 1-6.
Manahal Khalil
Membro desde: 09/11/21
217 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 26
Duração total: 888
