Introdução
Use this guide to restore wireless connectivity to your MNT Reform by replacing the WiFi card. Reform uses a standard mPCIe socket for WiFi cards.
O que você precisa
Remove the following screws securing the transparent acrylic bottom plate to the main box:
Ten M2×6mm silver Phillips screws
Pull out the eight battery cells one by one, and set them aside safely.
Unplug the UI1 (keyboard) and UI2 (trackball or trackpad) cables from the motherboard.
Use the flat end of a spudger or a clean fingernail to pry both antenna connectors up from their sockets.
Lift the acrylic holder with the Molex MIMO antenna out and set it aside.
Pull the two metal tabs holding the WiFi card away from the mPCIe socket. The WiFi card will spring up on its own.
To reassemble your device, follow these instructions in reverse order. Ensure that no cables are squeezed when replacing the bottom plate. Don’t overtighten screws.
Uma outra pessoa concluiu este guia.
