Ir para o conteúdo principal
MAGNAVOX MDV2300 Power Cord Replacement
O que você precisa
  1. MAGNAVOX MDV2300 Power Cord Replacement, Power Cord: passo 1, imagem 1 %32
    • Make sure the device is unplugged from the wall.
  2. MAGNAVOX MDV2300 Power Cord Replacement: passo 2, imagem 1 %32
    • Unscrew the two screws that hold together the top panel.
  3. MAGNAVOX MDV2300 Power Cord Replacement: passo 3, imagem 1 %32
    • Remove the top panel.
  4. MAGNAVOX MDV2300 Power Cord Replacement: passo 4, imagem 1 %32
  5. MAGNAVOX MDV2300 Power Cord Replacement: passo 5, imagem 1 %32 MAGNAVOX MDV2300 Power Cord Replacement: passo 5, imagem 2 %32
    • Remove disc drive by unscrewing the 2 screws that hold the drive in place.
  6. MAGNAVOX MDV2300 Power Cord Replacement: passo 6, imagem 1 %32
    • Identify the power cord.
    • The cord must either be too short or torn to warrant replacement.
  7. MAGNAVOX MDV2300 Power Cord Replacement: passo 7, imagem 1 %32
    • Cut the old wire out from the chip.
    • Attach the new wire into the housing.
    • Line up new wire with the appropriate holes and solder to board.
    • The white wire will be your neutral and the black wire will be your negative. View link of how to solder in order to replace the power cord. http://www.instructables.com/id/How-to-s...
Conclusão
After soldering, let cool and then reassemble your device, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Justin
Membro desde: 01/21/15
298 Reputação
Autoria de 2 guias
Equipe
Penn State, Team 1-41, Kaschak Winter 2015 Membro de Penn State, Team 1-41, Kaschak Winter 2015
PSU-KASCHAK-W15S1G41
Membros da 4
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 508
