Ir para o conteúdo principal
M3D Micro Z Axis Belt Replacement
  1. M3D Micro Z Axis Belt Replacement, M3D Micro Frame Removal: passo 1, imagem 1 %32
    • Removing the frame is necessary to access the z axis belt, motors and ports. Make sure the unit is unplugged and set on a hard level surface.
  2. M3D Micro Z Axis Belt Replacement: passo 2, imagem 1 %32 M3D Micro Z Axis Belt Replacement: passo 2, imagem 2 %32 M3D Micro Z Axis Belt Replacement: passo 2, imagem 3 %32
    • Pull the x-rods away from the plastic sliders on the y-rods, and flip the slider upwards to release the tracks. Lift the extruder assembly out of the way.
  3. M3D Micro Z Axis Belt Replacement: passo 3, imagem 1 %32 M3D Micro Z Axis Belt Replacement: passo 3, imagem 2 %32
    • No tools are required to remove the frame. Press down on the printing bed with your thumbs while lifting the frame with your fingers. The frame easily slides up.
  4. M3D Micro Z Axis Belt Replacement, Z Axis Belt: passo 4, imagem 1 %32 M3D Micro Z Axis Belt Replacement, Z Axis Belt: passo 4, imagem 2 %32 M3D Micro Z Axis Belt Replacement, Z Axis Belt: passo 4, imagem 3 %32
    • Remove the z axis belt from the device by simply lifting each corner of the belt off the corner gears and slide up over the z axis bars.
Conclusão
Danyel Browning
Membro desde: 09/28/17
255 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S3-G2, Nance Fall 2017 Membro de USF Tampa, Team S3-G2, Nance Fall 2017
USFT-NANCE-F17S3G2
Membros da 4
Autoria de 10 guias
Um comentário
Need a replacement z axis belt for my M3D micro printer don’t know where to go to get one
Ramon Arguello - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 1,953
