Ir para o conteúdo principal
Lytro Camera First Generation Repair
O que você precisa
  1. Lytro Camera First Generation Repair, Lytro Camera First Generation Lens: passo 1, imagem 1 %32
    • Pull the top off using your hands or the plastic opening tool.
  2. Lytro Camera First Generation Repair: passo 2, imagem 1 %32
    • Unscrew the four screws(7.1cm) seen after taking the top off.
  3. Lytro Camera First Generation Repair: passo 3, imagem 1 %32
    • Pry that silver piece off that you just took the four screws out of.
  4. Lytro Camera First Generation Repair: passo 4, imagem 1 %32
    • Take the camera out of the red part. You should have 3 piece not including the top.
  5. Lytro Camera First Generation Repair: passo 5, imagem 1 %32
    • Take the 3 screws(.5) out of the middle piece.
  6. Lytro Camera First Generation Repair: passo 6, imagem 1 %32
    • After taking that off you will see the camera lens.
  7. Lytro Camera First Generation Repair: passo 7, imagem 1 %32
    • Pry the piece hanging off with tweezers.
  8. Lytro Camera First Generation Repair: passo 8, imagem 1 %32
    • Now you can unscrew the three screws(.5) seen releasing the camera lense from the camera.
  9. Lytro Camera First Generation Repair: passo 9, imagem 1 %32
    • After that you can pull it off with the tweezers.
  10. Lytro Camera First Generation Repair: passo 10, imagem 1 %32
    • Now that you have it off you can replace it and reverse the steps getting it back together.
Conclusão
Jeremiah Killam-Hull
Membro desde: 02/08/17
109 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 13
Duração total: 479
