Ir para o conteúdo principal
Lumen Projector Bulb Replacement
O que você precisa
  1. Lumen Projector Bulb Replacement, Unplug projector: passo 1, imagem 1 %32
    • Unplug the projector from the wall outlet to allow for the light bulb to cool for at least 30 minutes.
  2. Lumen Projector Bulb Replacement: passo 2, imagem 1 %32
    • On the bottom side of the projector, locate and unscrew the back cover using a Philip's head screwdriver.
  3. Lumen Projector Bulb Replacement: passo 3, imagem 1 %32
    • Unscrew the bulb screws on either side of the silver plate.
  4. Lumen Projector Bulb Replacement: passo 4, imagem 1 %32
    • Remove the light bulb from the projector by lifting the silver handle and pulling up.
  5. Lumen Projector Bulb Replacement: passo 5, imagem 1 %32
    • Clean the now vacant area where the light bulb once belonged of dust and particles using a Q-tip.
  6. Lumen Projector Bulb Replacement: passo 6, imagem 1 %32
    • Use a new Q-tip to clean the fan blades and hole in which the light enters.
  7. Lumen Projector Bulb Replacement: passo 7, imagem 1 %32
    • Open and remove the new light bulb from its box with clean hands to prevent from getting the bulb dirty.
  8. Lumen Projector Bulb Replacement: passo 8, imagem 1 %32
    • Place the new bulb inside making sure to align the bulb towards the light hole and the wire connector towards the wire receiver.
  9. Lumen Projector Bulb Replacement: passo 9, imagem 1 %32
    • Dispose of the bulb by sending it to a recycling center.
Conclusão
Uma outra pessoa concluiu este guia.
Desiree Benitez
Membro desde: 01/21/17
128 Reputação
Autoria de 1 guia
Equipe
Um comentário
Thanks for your guide provide a step-by-step process on how to safely remove and replace a light bulb for a Ben-Q projector , how to projector Epson, is it same? because i have rental LCD Projector, definitely one day need
ericserianto - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 761
